Pull-Down resistor on the multiple channels NI9472
I noticed that my NI9472 did not toggle between Vsup and COM when I wanted to create PWM signal. I found that pull-down resistor can help and it helped. I based on the 'Troubleshooting Digital Output and Pulse Generation NI C Series Devices'
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8gGSAS
I would like to do it on the more than one channel. Do I have to add a pull-down resistor to each channel or I can connect all channels to the one pull-down resistor to simplify the wiring? Could somebody clarify it?
I want to on the 4 channels PWM signal and on the others trigger external relays.
Thanks in advance
Kamil
(2,502 Views)
Accepted by Nemesis
That would short all of the lines together.  You definitely do not want that.  Each line needs its own pull-down resistor.
(2,491 Views)
Ok, thanks for replay. What I was afraid. Thank you.
(2,485 Views)
