Python API Measurement usage
Hello everyone.
This is my first post on this forum, so please bear with me :). I had a lot of tries to make the program work but then I succumbed to the erros that I had...
I have a USB-6216 device which will be used to read data from 2 sensors. One will output pulses and the other will output an analog value. The cycle for the measurement will be 50 ms. My task is to have a python script that reads the data from the USB and after some postprocessing, outputs the data to a file (with a new file generated every 5 min). I managed to do the postprocessing and also the outputting of data but I am having serious difficulty setting up the data acqusition tasks.
I managed to also make the acquisition of Analog Data work using Software-Timed Acqusitions. I had a while loop run every 50ms while reading a sample every cycle.
Unfortunately, a specific requirement is to use Hardware-Timed Acquisitions. I want to store the number of pulses detected and the analog measurement in the on-board FIFO and then when the 50 ms are up, send the data over the USB to the PC. I thought about implementing this using the Watchdog timer. I aimed to reset the task every 50 ms using it, but I am not sure if this is the correct usage of the Watchdog.
This is what I tried to do so far (for the digital pulse input task):
with  nidaqmx.Task() as task:
   task.di_channels.add_di_chan("Dev1/port0")
   task.timing.cfg_implicit_timing(sample_mode=AcquisitionType.CONTINUOUS)
   system.watchdog.WatchdogTask("Dev1",task,0.05)
   print(task.read())
Any help is very much appreciated.
Thank you in advance.
Eduard
Message 1 of 1
(2,136 Views)
