sbRIO-9651 set default gateway from CLI
I have a 9651 configured with an incorrect default gateway.  I can only access the unit via ssh, so I need to change the default gateway via the command line.  route add/route del work fine, but when the unit reboots it comes back up with the incorrect gateway.  I changed the default gateway in /etc/natinst/share/ni-rt.ini, but when the unit reboots that entry gets reverted to the incorrect value.  Does anyone know where the default gateway value is stored?  Thanks.
Matt
(2,604 Views)
Hi Matt,
This issue is specifically with the NI Linux Realtime OS correct? If thats the case you may have better luck getting support from the NI Linux-Realtime discussion forums.
https://forums.ni.com/t5/NI-Linux-Real-Time-Discussions/bd-p/7111
(2,567 Views)
Thanks, I will give that a try.
Matt
(2,562 Views)
