Question about NI 9213
I need to estimate the temperature measurement uncertainty when using type-T TCs measured by the NI 9213. In order to do so, I need to know what is the confidence interval or the probability distribution function associated to the numbers published in figures 6 to 10 of the NI 9213 operating instructions and operations manual.
Thanks in advance,
Christian
(3,326 Views)
Hello Christian,
I brought the above question to R&D and discovered that those specs weren't derived from probability but is the accumulation of the total worse case scenario specs of supplier parts.
Glenn
(3,257 Views)
