Questions about GPSDO compatibility and setup with USRP-2920
I am a university student conducting research using a USRP-2920.
As part of my experiment, I am installing a USRP GPS-Disciplined Oscillator Kit (Ettus Research) inside the device to reproduce and analyze GPS meaconing signal behavior for academic study related to synchronization and timing.
Since the USRP-2920 is equivalent to the Ettus Research USRP N200/N210, I would like to confirm the following points to ensure proper installation and operation.
However, at the moment, the GPSDO does not seem to be functioning correctly — it is not being recognized by the USRP or showing signs of GPS lock. I would appreciate your guidance in troubleshooting this issue as well.
  1. Compatibility Confirmation
    • Is the USRP GPS-Disciplined Oscillator Kit officially compatible with the USRP-2920?
    • Are there any specific hardware, firmware, or UHD version requirements?
  2. Setup and Recognition
    • How can I verify that the GPSDO is correctly recognized after installation?
    • Is there a command such as uhd_usrp_probe to confirm GPSDO detection?
  3. Clock and Time Source Configuration
    • What is the correct way to configure the USRP to use the GPSDO as the reference clock and time source (e.g., set_clock_source("gpsdo"))?
    • Are these settings applied automatically?
  4. GPS Lock and Operation Check
    • How can I verify that the GPSDO is locked to GPS and operating correctly?
    • How long does GPS lock usually take?
  5. Antenna and Setup Recommendations
    • Are there any recommendations for antenna type, placement, or cable length for stable operation?
Thank you in advance for your advice and any related documentation.
Message 1 of 1
(129 Views)
