RIO and DAQmx
HI
i would like to know if it's possible to use DAQmx with myRIO , because i use DAQmx and i want to test it using myRIO device!
(4,501 Views)
No, DAQmx will not work on a myRIO.  What exactly are you trying to do with the myRIO?
(4,495 Views)
i must design an user interface to monitor some sensors  in a house like light, temperature, fire alarm, ...
(4,490 Views)
There are plenty of libraries for the myRIO to do the reading of the channels for you.  If you can use DAQmx, you can certainly figure out this library.
(4,486 Views)
