cRIO 9023 setting factory default
I want to reset my cRIO9023 to the factory defaults.
How do I do it?
What is the default IP address?
Which IP will it get when I use the IP reset button? Will it be DHCP?
(10,254 Views)
Accepted by topic author Simorgh
open MAX (Measurement & Automation Explorer), find your device and right click it. Then click format disc.
Default  IP Adress is 0.0.0.0. You can set the Network Settings yourself (DHCP, Static, Link-Local)
Here are some links. Please read the instructions carefully.
How Do I Format My Real-Time Target and Reinstall the Software?
Install and Configure compact RIO Hardware
Best,
Anna
Anna Vogl
Certified LabVIEW Developer
(10,192 Views)
Thank You.
(10,137 Views)
