RT Set Date Time and Fractional Seconds. Also NTP directly to target.
bradh,
No, I meant you should keep in sync by using SNTP from the RT PXI system to your NTP server.
Examples of how to do this are here:
    http://zone.ni.com/devzone/cda/epd/p/id/1487
    http://zone.ni.com/devzone/cda/epd/p/id/1558
These examples work OK, but as they update the normal PXI RT clock they are only accurate to the nearest second.
My suggestion is to modify the examples so they will update a custom counter-based clock (as described in my earlier post).  That way you can achieve the accuracy you're after.
Ian
Message 11 of 13
(2,007 Views)
ahh.... sorry missed the connection back to the original VIs.  Good idea - I'm going to try and implement it.
Message 12 of 13
(2,004 Views)
Just wanted to add a note that the software 1588 is now released as NI-TimeSync 1.0: http://joule.ni.com/nidu/cds/view/p/id/2083/lang/en
-Adam
Message 13 of 13
(1,580 Views)
