RT file I/O hangs timed loop
After porting a RT project from LabVIEW 8.5.1 to 2010 I started experiencing issues where after a couple of hours one of 6 timed loops I am using would hang.  This occurred in both debug mode and when executing the built application.  After quite a few hours of debugging I have narrowed it down to a possible problem when using file I/O in timed loops on an RT system.
I have included an application that contains 2 timed loops one of which is opening/creating a text file, writing some text to this file and then closing the file.  The behavior that I am experiencing is that the timed loop that contains the file I/O eventually hangs.  If this timed loop is changed to a while loop then neither of the loops hang.
Can anyone confirm whether there is indeed a fault with timed loops in LabVIEW 2010 or whether I a have something wrong with my installation of LabVIEW?
I am currently using LabVIEW 2010 DS2 and NI-RIO 3.5.1 on cRIO-9014 and cRIO-9073.  Both cRIO's show the same behavoir.
Rob
(4,073 Views)
Hi Rob,
I've been running your test VI on my computer here (LabVIEW 2010, Windows 7) for a couple hours, and I haven't seen any hang behavior from the file I/O loop. At this point, there are no known issues with Timed Loops in 2010. Do you have any sense of special conditions that might cause the hang?
Andy H.
(4,018 Views)
Run it on an RT controller
(4,014 Views)
Hi Andy,
Have you tested this on the cRIO-9014 and 9073?  This issue seems to be specific to RT.
Rob
(4,008 Views)
Hi Rob,
Thanks for the re-direct, I was able to reproduce this on a 9073. This was reported to R&D (corrective action request #214156) for further investigation. In the meantime, this Developer Zone on using File I/O in RT may help point towards a workaround for your particular application.
Thanks for the feedback!
Andy H.
(3,971 Views)
Hi Andy,
Thanks for your response.  I have already converted all timed loops to while loops which seems to work fine for this app.  Hopefully a patch can be issued soon as we intend to port other RT apps that required timed loops to achieve thread synchronisation, to 2010.
Rob
(3,953 Views)
