The library files"nidaq32.lib and nidex32.lib" can't be used in C++ Builder 5?
My DAQ board is NI-DAQ 6071E. I developer my application in C++ Builder5.I add these two library files in the project.But When i link,the linker say "[Linker error] 'E:\PROG\LIB\NIDAQ32.LIB' contains invalid OMF record, type 0x21 (possibly COFF)". These two library can used in VC++, Why can't used in C++ Builder? How can i resolve this problem ?
(4,920 Views)
NI-DAQ does not support Borland Builder C++. This information can be found in the NI-DAQ User Manual under language support. However, NI-DAQ does support Visual C++, Borland C++, Borland Delphi, and Visual Basic.
Erin
(4,920 Views)
I have been using Borland C++ Builder 5 with NI-DAQ with no problems for about a year and a half. I am surprised by the "not supported" comment considering the fact that NI-DAQ comes with the Borland library files nidaq32b.lib and nidex32b.lib, which work fine. Include these, not the Microsoft C++ library files nidaq32.lib and nidex32.lib.
When the library files are not available, then you can use the implib.exe program in Borland C++ Builder's bin directory. For example, you would call it like this at the command prompt: implib nidaq32.dll nidaq32b.lib (naturally, nidaq32.dll must be in the current working directory for this example to work).
(4,920 Views)
Can you tell me what for example you uesed, when you need the librarys nidaq32.lib and nidex32.lib
(3,235 Views)
