I am also working with RT,I am not able to see CPU usage with my system manager,its showing some VI server error or port error?how should i configure,i gave IP address but use default port address.please solve this problem?
Could you please discribe your problem a little better. Give error codes, discribe what VI you are running, describe the behavior. Use good punctuation and grammar too 🙂
Message Edited by rex1030 on 05-07-200804:54 PM
--------------------------------- [will work for kudos]
Rex1030 is correct. Waits inside of loops help with 100% CPU. Also note that if you are using a cFP, the default action is to run at 100%. Note this: http://digital.ni.com/public.nsf/allkb/8CBE08A24018A8F086256F79006CEB12?OpenDocument
Are you using a cFP.
"If you want to succeed... Architect" - The Specialist
