Reading own Image Version
In MAX under remote systems, in the system settings tab, there is an "Image Version" listed. Can I read that from LabVIEW from the remote target? I'm guessing that comes from a file somewhere. What's the path? Target is LinuxRT FYI.
(2,393 Views)
Accepted by nanocyte
Hello nanocyte,
I would try getting it using the System Configuration VIs and Property Nodes. Hopefully this gives you the information you're looking for:
Warm regards,
(2,361 Views)
