Recommendations for Wind Speed Meter that can be read by Labview?
I'm trying to read back a fan speed into Labview to make sure that I'm getting the proper mass flow rate.  Is there a recommended wind speed meter (anemometer) that could be controlled and or monitored using the Labview interface with or without a data acquisition device?  Any recommendations would be helpful!
Ambert
(3,411 Views)
Ambert-
Depending on the resolution and speed of the measurements you are looking for, there is a National Instruments product that will be able to handle this.  As far as a transducer, National Instruments does not recommend 3rd party products.
Why did you post under the Real-Time Measurement and Control board?  You may find better help and more traffic from the community posting under the Multi function DAQ board.
Mike S
NI AE
(3,396 Views)
