Sample Project NI 5791 and NI PXIe-7972R
Is there any sample project in LabView 2015 for Simple Data Streaming using FlexRIO NI 5791 and PXIe-7972R?
We checked that the sample project in LabView 2015 only contains example with following combinations :
- NI 5791 with PXIe-7966R, and
- NI 5791 with PXIe-7975R
Any reply will be appreciated.
Thanks.
(5,021 Views)
Accepted by centrums.ni
If you add a 7972 to the project you can just highlight all the folders, the VI, and the 200MHz Clock under the 7975 and copy them to the 7972. From there all you ned to do is add the IO Module to the target and you're good to go.
(5,011 Views)
Thank you very much for your help.
with a little bit of FPGA compiling, now it's working
(4,997 Views)
