Search for online cRIO
I'm trying to detect connected and running cRIO in the local network based on the status (Connected - Running/Disconnected). Reason I'm doing it like this is, that when the device is powered off, it still can be found by Find Hardware.vi.
Snipped in the attachment basically does what I'm looking for, but I'm having problem with the Initialize Session.vi which takes from 6s to 50s, when the device is not connected or powered off. No problem when the device is connected and powered on.
Does anyone know why Initialize Session.vi takes so much time?
Could you recommend other solution to searching for cRIO?
Duri
Message 1 of 10
(5,109 Views)
It may take that long, because Initialize Session.vi waits for a confirmation from the cRIO, but as the cRIO is not powered on, it waits until timeout event occurs
Message 2 of 10
(5,082 Views)
if you are trying to detect if a certain cRIO is connected, you can implement a heartbeat monitoring using a dedicated shared variable, which can store the time it has been modified,  and by checking that time you can make sure if the RIO is online.
Message 3 of 10
(5,079 Views)
Hi hy_,
I understand this and would say that it is expected behavior, but Initialize Session.vi has Connect Timeout (4000 ms) input, which does not seems to work.
To your second reply:
Once I successfully connect to cRIO, I'm monitoring "vital" functions. So this is handled. But the problem is when I'm starting the Main Host application and searching for particular device, which might be powered off if the user forgot to have device powered on and connected prior to starting Main Host application.
Duri
Message 4 of 10
(5,078 Views)
According to specifications, initialize session can take longer than the specified timeout in some occasions.
https://zone.ni.com/reference/en-XX/help/373107N-01/nisyscfg/initialize_session/
Message 5 of 10
(5,074 Views)
Message 6 of 10
(5,071 Views)
Yes, so some occasion seems to be the basic one, when the device is not connected.
Is there any other way to detect online cRIO except using Initialize Session.vi and Status System property?
The other one was already reported to moderator.
Duri
Message 7 of 10
(5,068 Views)
Accepted by Duri
We can set a static IP address on cRIO and ping it to check whether it's online
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z00000159SmSAI&l=en-GB
Message 8 of 10
(5,066 Views)
Well, shame on me.
Thanks.
Duri
Message 9 of 10
(5,058 Views)
glad to assist you ❤️
Message 10 of 10
(5,055 Views)
