Send acquired data to cRio through Ethernet
Hi!
A PC is acquiring data from sensors ( rate = 500hz), and I would like to send this data to cRio module each time a value is acquired using an Ethernet connection.
Is it possible ? Is latency time of the ethernet bus will be a problem in that case ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,600 Views)
consider
http://zone.ni.com/devzone/cda/tut/p/id/3098
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,593 Views)
Perfect! Everything's inside !
(3,586 Views)
