Set sbRIO analog IO to raw uncalibrated
For cRIO modules you can select between raw and calibrated IO by right clicking on the module. I have an sbRIO 9627 but I don't see any modules that can be configured. Can I get the data as raw?
Message 1 of 8
(4,740 Views)
Are you using an expansion chassis with some extra c-series modules? Which specific channel are you using and what kind of data is being displayed from that channel?
Regards!
Message 2 of 8
(4,710 Views)
sbRIOs don't have expansion chassis and I'm not using modules. I'm using the MIO port. AI0-15 AO0-3. The IO node on the FPGA appears as a fixed point integer from -10 to +10 volts. I want it to appear as the raw ADC counts. Maybe as an I16 from -32768—32765
Message 3 of 8
(4,705 Views)
Accepted by nanocyte
There is no way to get raw data directly from the IO node on a sbRIO, you would have to programmatically convert it to binary.
FYI: the sbRIOs have an Ethernet port from which they could be using an Ethernet or EtherCAT expansion chassis with c-series modules
Message 4 of 8
(4,692 Views)
Hey nanocyte,
What is the motivation to have raw data? Perhaps there is a different option to acheive whatever your end goal is.
The thread you linked in the original post is a 9263. The option to get that data as raw vs calibrated probably had to be separately implemented on the driver / IO Node side. This options existence varies by module.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
Message 5 of 8
(4,685 Views)
Thank you for following up. My primary goal was to reduce FPGA resource usage. I don't need calibrated data and it might be more intutive to program with raw. Imagine something as simple as AO1=A01+1 to generate a ramp.
Message 6 of 8
(4,678 Views)
Ah, a good goal. Reducing the use of fixed point numbers is definitely an optimization. It looks like using raw data might not be a possible way to optimize this program. If you haven't already found it, the High Performance Dev Guide might be something for you. It's free, and a great resource. Other quick ways you can optimize are by reducing front panel objects, reducing the frequency you update those objects, and avoiding arrays on the front panel.
Andrew T.
Message 7 of 8
(4,668 Views)
I made an idea on the exchange supporting the addition of this functionality
https://forums.ni.com/t5/LabVIEW-FPGA-Idea-Exchange/Allow-raw-access-to-sbRIO-Analog-IO/idi-p/354923...
Message 8 of 8
(4,653 Views)
