Sine generator with cRIO
Hey Ashokan,
You should be able to save a .jpg file to your cRIO. How were you trying to do this when it wasn't working?
Doug B
Message 11 of 15
(1,923 Views)
Hi Doug
I checked this jpeg vi, worked perfectly in my PC and that file size comes out around 160kB.
The same vi when it deployed, loops run without any error. But it won't create any jpeg file.
Thanks & Regards,
Ashokan. M
Ocean Acoustics,
National Institute of Ocean Technology,
Chennai, India - 600100.
Message 12 of 15
(1,920 Views)
Ashokan,
Are you trying to both create and also save the .jpg file on the cRIO? I know you can save a previously saved .jpg onto a cRIO.
Doug B
Message 13 of 15
(1,908 Views)
Hi Doug,
I rectified the error.
Now I need help to tranfer files from cRIO to PC programmatically.
I tried a lot; results negative.
Thanks & Regards,
Ashokan. M
Ocean Acoustics,
Message 14 of 15
(1,898 Views)
Hey Ashokan,
What techniques have you tried for file transfer that hasn't worked out for you so far?
I would recommend using the FTP VI's in LabVIEW. You can find the FTP file vi's in your functions under Connectivity > Internet > FTP
http://www.ni.com/support/labview/toolkits/internet/ftp.htm
Tim A.
Message 15 of 15
(1,883 Views)
