Startup Application and shared variable issue with cRIO 9053
I am currently utilizing NI-cRIO-9053 with LabVIEW 2025 to publish shared variables on the network, enabling a PC to access them via an application built from “My Computer Shared Variables Test.vi” without LabVIEW installed. However, the shared variables are not being published successfully, even on a PC with LabVIEW installed. I have created a Real-Time (RT) application, deployed it to the cRIO with "run at startup" enabled. Nevertheless, the application requires manual execution of the VI to read the shared variables. What is the underlying issue preventing the shared variables from being accessed as expected?"
(282 Views)
Try Deploying Network Shared Variables from a Compiled Executable
https://tmesystems.net/
(252 Views)
