Stopwatch that activates and deactivates based on input signal
I'm really new to Labview programming, and I'm slowly learning the basics. I'm trying to make a stopwatch that response to an input signal.
The problem is this:
Given a continuous input signal Y (volt). Most of the time, the signal is 0. Sometimes (user input on sensor change the signal), the signal has values from 5-10. When y > 7, the timer start. And then when y becomes < 7 again, the timer stop and output the time the signal stays high than 7. This repeats forever.
Summary: start stopwatch when signal is > 7, stop when signal < 7. Output the measured time.
I can make the stopwatch activate/deactivate with a button, but I don't know how to do it with a signal
I need a block that can be both a control and an indicator (so I can do block = !block to perform boolean switch), but I can't find it and I think it doesn't exist. So I can't do it that way.
How can I solve the problem I described? Thank you.
(2,280 Views)
May you please share the vi?
Why can't you just use comparison functions and based on output start the timer?
Also, I'd recommend to use FGV timer.
https://forums.ni.com/t5/Example-Code/FGV-Timer-SubVI/ta-p/3499484
(1,753 Views)
