TDMS Create or Replace Returns Error
This example using the FPGA option (near the end of the page):
http://zone.ni.com/devzone/cda/tut/p/id/11198#toc4
Step #26 under FPGA section sets up the open or create TDMS file.
This always returns error #7 from the TDMS create or replace VI.  When creating a new file, it should not return error "cannot find file".
(3,887 Views)
Check that you have a valid file name.  It works for me under LabVIEW 2010.
If possible post the code or a snippet of code here and the error that is generated.
Cheers
Stephen
(3,875 Views)
Accepted by topic author rwestbrook
You are receving error 7 due to the file path that you are specifying. Make sure you are using the correct file path. If you are still having problems is a knowledgebase article that might shed some more light on what is going wrong.
http://digital.ni.com/public.nsf/allkb/BBCAD1AB08F1B6BB8625741F0082C2AF?OpenDocument
David A.
(3,866 Views)
I'm giving the reccomendations from this article a try.  It looks like I may have to try a few things before landing on the right combination.
I'll let you know how it goes for actually solving the problem, but so far this looks like the best lead yet.
(3,860 Views)
Thank You David A.
I had to use strip path / build path functions to create a file location that the cRIO actually understood.  Then everything worked fine.
Problem solved.
(3,856 Views)
