11-13-2007 09:04 AM
11-14-2007 04:57 AM
Have you read through the manual for the SCB-68 to ensure that you have connected the thermocouple to the correct terminals, and have also set the internal switches to enable the Cold Junction Compensation for the connector block? If you have not, this will cause readings that don't make any sense. Follow the link below for the manual:
http://digital.ni.com/manuals.nsf/websearch/74C86ADEF0E4813F86256C84007CB3AB
Dan
11-14-2007 06:58 AM
