The feedback node is not working and error message appears type not supported in the current targe
Hi All
I am doing a simple estimation program which tracks certain signals, I am using cRIO 9024 and I put some feedback nodes and some arithmatic operations in simple while loops with case selection. I am not able to compile the program since many error messages says the following:
Wire: type not supported in the current target
Attached is the VI model .... Thanks for your help
(3,988 Views)
FPGA code does not allow for Double Precision Floating Point numbers (DBL).  Change the initial condition constants to be either I16 or to match your fixed point data type.
(3,982 Views)
