Thermo-hygrometer compatible with labview
Goodmorning,
I'm looking for a thermo-hygrometer (device which can mesure temperature and humidity) compatible with labview and if possible with a USB connector.
Did you ever heard/use a such device ? I've made some ressearch but I can't find this.
thank you by advance.
(4,590 Views)
I've used this one in the past but it depends on your specifications.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,577 Views)
Accepted by leoleoleo24
Thank you ! I found it an other which seems better but thank you ! ( Your Temperature range is smaller )
(4,553 Views)
