Timed loop execution time
Whenever i run a timed loop, even a dummy one, i get 100% CPU usage with "RT get CPU loads". The "Performance and memory" profiler and the "Execution trace toolkit" also indicate a maximum VI time. Is this normal?
(3,862 Views)
Accepted by Snamprogetti
Which RT target are you using? If it's a FP, you'll always have 100% CPU load due to performance optimizatio.
Best Regards,
Fabio
Fabio M.
NI
Principal Engineer
(3,848 Views)
