Unstable 9073
Hi all,
I have had this problem for some time now, but managed to overcome it by restarting the unit (9073). The problem is that the unit is behaving unstable, it starts already when Im using MAX; sometimes I can't find the unit until I restarted the unit (sometimes several times is needed). Then when I find it, I try to install software on it and this works most of the times but not all times - so I have to restart it, format it and start again. After some times the software has been successfully installed and I can deploy my project - this step is also causing problems sometimes, but restarting the unit may help. Thereafter it works most of the times, but then again it "hangs" - it is possible to ping the unit successfully but the communication with the installed application does not work unless the system has been restarted (sometimes several times of restart is needed). I have follows all the steps in the description of how to install the unit. This is the case for several different 9073s - so I can't blame just a bad unit. When I managed to install one system work  it is a much more stable way to install on other systems using ftp and copy the software&project than using MAX and LabView.
I have also tried different computers, to exclude the possibility that is related to just my computer. Has anyone else had this issue?
Does anyone have suggestions on how to try to understand what is happening, and how to overcome it?
Message 1 of 1
(3,913 Views)
