CompactRIO detected by the network browser, but not by MAX or LabVIEW
I have a CompactRIO hooked up through ethernet over the network. I am able to see the CompactRIO on the network browser, and it has an IP address. However, when I try starting MAX, I do not see the device there. I also am unable to see the device showing up in LabVIEW when attempting to add a new device to my project. The folder for CompactRIO is not showing up. All I have for options is Real-Time Desktop, Real-Time Industrial Controller, and Real-Time PXI. If I try to specify the target by IP address I am unable to see any of the connected modules.
(4,480 Views)
It sounds like you must have not have installed the NI-RIO driver. Can you confirm that?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,478 Views)
I will have to talk with the electronics shop guys. I am a student at UofH doing a senior design project, and dont have admin privileges on the computer being used.
(4,474 Views)
You can check this for yourself by going into Measurement and Automation Explorer and looking into the Software category.
Adnan Zafar
(4,472 Views)
I agree with Adnan that this is most likely an issue with the RIO driver not being installed. However, there are other things which could be causing this issue. Here is a troubleshooting guide that specifically addresses this problem. It may be best to also connect the cRIO directly to the PC through a cross over cable. You can rule out networking issues very quickly through that process.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(4,468 Views)
