Using CLIP - The wizard does not open
I am trying to use the CLIP for embedding a VHDL code. Unfortunately I cannot configure the IP node nor can I open the wizard from the Component Level IP tab on the FPGA properties. The message says that I don't have the necessary compilation tools, but I do have both XILINX ISE 10.1 and XILINX ISE 14.7 and both work properly. Is there another software I have to install in order to make it?
I use Labview 2016 and PCI-7833R FPGA.
Does anyone have a clue?
Many thanks!
(2,617 Views)
Two questions:
1. Which version of windows are you using?
2. Did you install the ISE from NI's website?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,588 Views)
Hi Terry,
Thank you for your response.
I use windows 10 and I did install ISE from NI's website.
Ori
(2,584 Views)
That version of ISE is not compatible with Windows 10.
ALE Consultants
(2,577 Views)
Is there another version of ISE that will fit both this model and windows 10 ?
(2,573 Views)
