Using a IEEE-1394 Firewire Kamera with an PC RT-Target
I need help using an IEEE 1394 Firewire Camera with a PC as Real-time-Target
running LabView Real-Time 8.5.1 and NI-IMAQ for IEEE 1394 RT 2.0.5
The Real-time-Target is running without any problems and the onboard IEEE controler was detected by the Real-time-OS
>> Found OHCI Compiant IEEE 1394 Host Controler
>> Location: bus 0 device 2 function 3
but if I connect the camera to the controler following message appears
>> Failed to start IEEE 1394 SBP2 Device Error code = -1217
The camera is normally supported by NI-Drivers and never made problems in non real time systems.
Can someone please help me with this problems?
(3,178 Views)
I solved the problem myself, or better worked around!
For all people having tthe same problem, the problem was not the camera, it was to onboard Firewire-A controler.
The controler was found on the real time Target:
but didn't work!
The new Controler is a PCI IEEE 1394 Controler fron NI
>> Location: bus 0 device 19 function 0
and works good.
All diference between working controller and the failed controler is function 0 and function 3 and of course the device number!
Hope i could help people having this problem in future!
Kind regards
RTuser
(3,154 Views)
