Using calibrated outputs for the NI-9205 as set from the project explorer
Hello All,
This is my first time putting together a project on the cRIO and I seem to be running into a little issue. I'm not able to get valid data out of the NI-9205 and I can't find what I missed.
I'm using labview 8.5.1 and as I understand it, the NI-9205 doesn't need to be calibrated or configured in the VI if the settings are configured in the Project Explorer. I want to take advantage of this so I stripped the calibration, channel setup, and bin-to-nominal converstions from the orginal example. Am I wrong in doing this?
As you can see from the pictures I'm 10 differential channels from the 9205 as well as also using a 9802 and 9485 in this project.
(3,218 Views)
Can you describe a bit more what seems to be the problem. Taking a quick look at your screenshots, everything seems to be okay. What signals are you connecting to the inputs of the 9205 module? What data do see returned from the FPGA (pictue of the graph with your signals) ?
You may also want to zip all the project files you have and attach the actual project/VIs with your post.
Message Edited by Christian L on 05-14-2008 09:43 AM
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,182 Views)
