write data to a excel sheet
Hi Friends,
I 've stuch with a issue...
Using one of the excel examples
i 'm reading the data from cells of excel (say 1:1,1:2....)
And its quite good....
where as i want to write the result back to the excel sheet....
I remember that this can be done thru Report generation tool kit with my previous exp..
could you please suggest the secondary option of without RGTool kit and doing it...
THnaks in advance..
CHeers,
Suneel
(3,098 Views)
Hi Suneel,
Another way of communicating between LabVIEW and Microsoft Excel is to use  ActiveX controls.  Excel actually has a lot of funcionality exposed through ActiveX. I am not sure how much work is required to accomplish what you are trying to do with this approach, but it is definetely doable.
Here are some resources that may help you find more information on this:
http://zone.ni.com/devzone/cda/tut/p/id/3520
http://support.microsoft.com/kb/222101
http://www.excelforum.com/
Eli S.
(3,078 Views)
