Variable container
I am using variable containers to dynamically discover c-series modules that are installed in the cRIO. I have an issue when I install only one module. Even though there is only a single module installed the children property node brings back a module 6. Any help on this would be appreciated.
JY
(4,050 Views)
Hi JY,
What slot is the module in when the property node brings back the module 6?  When you have 2 modules in slot 1 and 2 they show up as one and two?  Which version of Labview is this and what is your crio controller and chassis?  I may be able to replicate what is going on here.
Scott A
SSP Product Manager
(4,035 Views)
Accepted by jeffyy
Reformatting solved the issue.
(4,032 Views)
