What do I need to do to deploy my RT target to the cFP device?
I am trying to deploy the code to my RT target and get this error. "Unable to query Measurement & Automation Explorer for the Shared Variable Engine. Make sure the Shared Variable Engine exists on the RT target and check that the network connection is valid."  What do I need to do
(4,129 Views)
When you go to install software on your RT target (in MAX, Right click on software >> Add/Remove Software), you should include the "Network Variable Engine":
Double-check to make sure that this feature is installed on your target.  Does it still give you this message, even with the Network Variable Engine installed?
(4,115 Views)
