What is your suggest if my host computer controls various real-time system in the same time?
I plan to build a control system that my host computer controls many of real-time controllers.
I only have experience on 1-by-1 host and targer real-time system.
All I can think is that to create a network variable from each target, and run VI on host to load it.
Thank you very much for your recommendation.
Engineering at Sriracha
Kasetsart University
(4,662 Views)
Accepted by topic author Yaovaja
Hi Yaovaja,
Shared variables will be a good way to interact with your target.  You can find an example from Example Finder >> Toolkits and Modules >> Real-Time >> RT Network Communication
Attached is a picture of the example finder entry.
Regards
Che T.
(4,652 Views)
thank you
And also I can use shared variables link to varios CRIOs.
What is the benefic if I use such as ActiveX control.
(4,622 Views)
Hi CRVLAB,
Yes, you are correct regarding having the shared variables being shared between multiple cRIOs.
I'm not quite clear on what you mean by ActiveX control.  Can you clarify what you mean, and what you intend to do?
Che T.
(4,590 Views)
