multi-VI FPGA data aquisition
Hi.
In most of FPGA exaples I see, there is usually 1 FPGA vi that aquires data from multiple channels.I must be missing something fundamental, b/c, I have a rather complicated program I had work flawlessly in DAQmx, where I use DIO, AI and AO at diffrent subvis. Now, since converting my code to FPGA, my top priority host VI triggers a digital clock and an analoog output, and a host subvia aquires data (and if selected, outputs an analog waveform), another host subvi, write a waveform to the memory block, and yet another host subvi aquires data from another channel.
So the question here is, when I run my finished host Vi, I get errors saying that the FPGA is busy. Can the FPGA run one Vi at a  time? I need to run multiple fpga vis sometimes overlapping with eachother.
i also want to point out that i have no errors in running each fpga vi indipendantly, and I never have douple calling issue (each host subvi calls on a previously unopned fpga vi and closes it when done).
If someone has mannaged to decode my rant, 🙂 does this mean that I have to combine the functions all fpga vis into one giant fpga vi with multiple triggerable loops? meaning the fpga vi remain open, and each host subvi will boolean executes a loop (which was previously an fpga vi by itself) ?
I would upload vi but, my code only works as a unit and it has many many subvis.I would appericiate any help especially answering my central question, does fpga only have capacity to excute one vi at a time?
thanks loads-
ArifH
(4,186 Views)
Hi
why would  you want to run yourFPGA  vi's separately ?
Utilise the parellelism of the FPGA  : instead of multiple vi's impliment you code in main FPGA with independant loops for each 'module'.
So your RT code would then address the 'independant loops', memory blocks etc.
take a look at :Using Multichannel Butterworth Filter - cRIO.lvproj in the examples.
If you then added an encoder 9411 the code would be put on the FPGA block diagram but independant to the other code.
Hope that helps
xseadog
(4,168 Views)
