Why the output rate of python code is soo low?
Good afternoon I am using the acquistion board PCle-6346 controlled using python to acquire samples from a position sensor which is the Keyenche IL-030S.
Now, i set the sampling frequency of the board at 500 kHz and the buffer size to the minimum of 2 but the python script i made gives out a reading every 0.095 s which is a little more than 10 Hz. As I am quite new in the field I was wondering how i can imoprove the output rate of my code to be at least 100Hz or more.
Thanks to everyone for your time and support
import numpy as np
import nidaqmx
from nidaqmx.stream_readers import AnalogMultiChannelReader
from nidaqmx.constants import Edge, AcquisitionType, TerminalConfiguration
import time
def acquire_data(buffer_size, freq_sampling😞
    with nidaqmx.Task() as task:
        start_time = time.time()
        task.ai_channels.add_ai_voltage_chan("Dev1/ai0")
        print("time:", time.time() - start_time)
        task.timing.cfg_samp_clk_timing(freq_sampling, sample_mode=AcquisitionType.FINITE, samps_per_chan=buffer_size)
        data = np.zeros((1, buffer_size))  # Placeholder for the acquired data
        reader = AnalogMultiChannelReader(task.in_stream)
        reader.read_many_sample(data, number_of_samples_per_channel=buffer_size)
        print("time:", time.time() - start_time, 1/(time.time() - start_time))
        print("\n")
    return data.flatten()
while True:
    data = acquire_data(2, 500000)
(799 Views)
Accepted by topic author filippo1699
Because Python is an interpreter language and is much slower than C or C#. Reference: C++ vs. Python: A Performance Comparison using an Example
Use LabVIEW, C or C# if you want to read the data more frequently. See Getting Started with NI-DAQmx for Text-Based Programming
https://tmesystems.net/
(780 Views)
Crystal clear!!
Thank you so much for your fast and precious answer!!!!
(752 Views)
