'opkg update' returning gpg signature verification errors
I wanted to update the software installation of a cRIO 9041 through MAX, but received this strange error instead:
This cRIO doesn't have any custom feeds, so I tried running opkg update manually and it came back with a gpg signature verification error:
admin@NI-cRIO-9041-xxxxxxxx:~# opkg update
Downloading http://download.ni.com/ni-linux-rt/feeds/dist/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/dist/Packages.asc.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/all/Packages.asc.
Updated source 'uri-all-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/x64/Packages.asc.
Updated source 'uri-x64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/core2-64/Packages.asc.
Updated source 'uri-core2-64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/all/Packages.asc.
Updated source 'uri-all-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/x64/Packages.asc.
Updated source 'uri-x64-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/core2-64/Packages.asc.
Updated source 'uri-core2-64-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-lv2020/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-lv2020/Packages.asc.
Updated source 'ni-labview-2020'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-main/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-main/Packages.asc.
Updated source 'ni-software'.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/x64/Packages.asc.
Updated source 'salt-x64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/core2-64/Packages.asc.
Updated source 'salt-core2-64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/all/Packages.asc.
Updated source 'salt-all-0'.
Collected errors:
 * opkg_verify_gpg_signature: Signature status returned error: Bad signature
 * pkg_src_verify: Signature verification failed for NI-dist.
Thinking perhaps something on the cRIO was corrupt, I formatted it and attempted to set it up through MAX. It go so far as checking for access to the NI feeds, then MAX crashed completely:
Process: NIMax.exe
OS: Windows 10 Professional  (10.00.19045)
2024-04-16 15:48:56.132 Caught exception!
Minidump filename: 984560b2-d66d-40dc-838a-5ffbeaabb3df.dmp
Exception details:
NationalInstruments.SystemConfiguration.SystemConfigurationException: Running 'opkg update' failed to access at least one enabled feed. Consider disabling unnecessary feeds.
   at NationalInstruments.SystemConfiguration.SystemConfiguration.GetAvailableSoftwareComponents(ComponentTypeFilter componentsToInclude)
   at NationalInstruments.RemoteConfiguration.SystemConfigurationSession.<GetAvailableSoftwareComponentsAsync>b__19_0()
   at System.Threading.Tasks.Task`1.InnerInvoke()
   at System.Threading.Tasks.Task.Execute()
Is there something wrong with the NI feed? I'll probably do a legacy install or offline install if this issue persists, but would be nice to know the root cause.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(1,785 Views)
Maybe try again later.
https://tmesystems.net/
(1,758 Views)
Which Base System Image is used?
(1,747 Views)
Hi @MichaelBalzer, there were updates recently. We are double checking to make sure all is well on the back end.
(1,743 Views)
It was Q1 2020.
It's all working again now after a cache update on the server end. Thanks @AustinMan@NI.
(1,698 Views)
