 MichaelBalzer
			MichaelBalzer
			04-16-2024 03:48 AM
I wanted to update the software installation of a cRIO 9041 through MAX, but received this strange error instead:
This cRIO doesn't have any custom feeds, so I tried running opkg update manually and it came back with a gpg signature verification error:
admin@NI-cRIO-9041-xxxxxxxx:~# opkg update
Downloading http://download.ni.com/ni-linux-rt/feeds/dist/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/dist/Packages.asc.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/all/Packages.asc.
Updated source 'uri-all-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/x64/Packages.asc.
Updated source 'uri-x64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/extra/core2-64/Packages.asc.
Updated source 'uri-core2-64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/all/Packages.asc.
Updated source 'uri-all-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/x64/Packages.asc.
Updated source 'uri-x64-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/x64/main/core2-64/Packages.asc.
Updated source 'uri-core2-64-1'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-lv2020/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-lv2020/Packages.asc.
Updated source 'ni-labview-2020'.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-main/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/2020/ni-main/Packages.asc.
Updated source 'ni-software'.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/x64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/x64/Packages.asc.
Updated source 'salt-x64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/core2-64/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/core2-64/Packages.asc.
Updated source 'salt-core2-64-0'.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/all/Packages.gz.
Downloading http://download.ni.com/ni-linux-rt/feeds/SystemLink/salt/20.0/x64/all/Packages.asc.
Updated source 'salt-all-0'.
Collected errors:
 * opkg_verify_gpg_signature: Signature status returned error: Bad signature
 * pkg_src_verify: Signature verification failed for NI-dist.
Thinking perhaps something on the cRIO was corrupt, I formatted it and attempted to set it up through MAX. It go so far as checking for access to the NI feeds, then MAX crashed completely:
Process: NIMax.exe
OS: Windows 10 Professional  (10.00.19045)
2024-04-16 15:48:56.132 Caught exception!
Minidump filename: 984560b2-d66d-40dc-838a-5ffbeaabb3df.dmp
Exception details:
NationalInstruments.SystemConfiguration.SystemConfigurationException: Running 'opkg update' failed to access at least one enabled feed. Consider disabling unnecessary feeds.
   at NationalInstruments.SystemConfiguration.SystemConfiguration.GetAvailableSoftwareComponents(ComponentTypeFilter componentsToInclude)
   at NationalInstruments.RemoteConfiguration.SystemConfigurationSession.<GetAvailableSoftwareComponentsAsync>b__19_0()
   at System.Threading.Tasks.Task`1.InnerInvoke()
   at System.Threading.Tasks.Task.Execute()
Is there something wrong with the NI feed? I'll probably do a legacy install or offline install if this issue persists, but would be nice to know the root cause.
 ZYOng
			ZYOng
			04-16-2024 07:19 AM
Maybe try again later.
 hy_
			hy_
			04-16-2024 08:27 AM
Which Base System Image is used?
 AustinMan@NI
			AustinMan@NI
			04-16-2024 08:35 AM
Hi @MichaelBalzer, there were updates recently. We are double checking to make sure all is well on the back end.
04-16-2024 09:56 PM
It was Q1 2020.
It's all working again now after a cache update on the server end. Thanks @AustinMan@NI.
