Write to file in myRio
Hi,,
my code connot write data from myrio to my PC, I need you help to fix it. Plz,,
Message 1 of 12
(9,135 Views)
The myRIO doesn't actually run on your computer.  It has its own OS and file system.  Would you expect your friend's computer to write to your computer's harddrive?  Well, it can if you use a shared folder and address the folder with the network name.  So you need to supply a network address for your shared folder on your system that the myRIO can then write to.
Message 2 of 12
(9,128 Views)
Thank you for your reply and help
actually , I just need write  data on file  when I run the system.
Message 3 of 12
(9,126 Views)
I don't understand what you mean by this.
Message 4 of 12
(9,123 Views)
I mean my code cannot wirte data to file
Or the wirte to file box not working with myrio
Message 5 of 12
(9,116 Views)
Write*
Message 6 of 12
(9,115 Views)
Again, the myRIO is its own little computer.  Anything that you run will be ON THE MYRIO.  The myRIO doesn't have a GUI.  So you need to supply the file path manually and you need to give it a network address if you want it writing to your harddrive.  Otherwise it tries to write on its own flash drive.
Message 7 of 12
(9,113 Views)
I see.
So, could you give me an example code for write data on myrio drive.plz
or any helpfull link.
Thanks alot
Message 8 of 12
(9,110 Views)
Here's a couple of articles to read:
Under the Hood of NI Linux Real-Time
Working with File Paths on Real-Time Targets
Message 9 of 12
(9,102 Views)
Message 10 of 12
(9,096 Views)
