Writing file to internal storage
I am working on a multi channel standalone data logger project based on SingleBoardRio. As much as i know, sbRIO9612 has 256MB NonVol. Memory. I want to write configuration file and data this memory, but couldn't find if I can - how I can. I saw many examples about writing a file to a host PC but not RT targets, is this possible?
Thanks in advance,
(3,686 Views)
You can write any data or files to the Flash Drive (NonVol. Memory) on the sbRIO controller using the standard LabVIEW file I/O functions in your LabVIEW RT VIs. The drive is listed as C, so specify your file names in the same manner as on Windows using C as the drive letter and any desired folders.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,670 Views)
If 256MB is not enough, we also have the 9802 SD Card Module which provides up to 4GB nonvolatile storage. You will assign a drive letter like U: or V: when using this.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,643 Views)
