cRIO-9014 Serial Input
I am very confused about how to use the serial port of a cRIO-9014. I have some VIs, attached, to send and recieve data from my device via serial port, they are working well, the program do this:
PC --> Serial (COM1) --> Device  --> Serial (COM1) --> PC
Now I want to replace PC with the cRIO-9014:
cRIO-9014 --> Serial (COM1?) --> Device  --> Serial (COM1?) --> cRIO-9014
My confusion is that COM1 is the name of the port in the PC, how do I set the communication via serial between cRIO and my device?
Thanks.
--Luis
(3,868 Views)
Sorry about the question, I haven't realized that when you deploy a project the serial ports available are the ports in the cRIO.
--Luis
(3,856 Views)
