cRIO 9055 General Use Question
Hello all,
Recently I've been working with a cRIO 9055 and I'm not entirely sure about how it's meant to be implemented.
To clarify, I've looked over different tutorials \ forum threads \ user manuals \ etc., but I can't seem to figure out if there's a way to directly connect a monitor to the cRIO itself (along with other devices such as a mouse and keyboard), or if a host computer is effectively necessary in order to operate it.
For context, the project I'm building requires the cRIO run in a hybridized mode with FPGA modules and a real time scanning module operating simultaneously. I was trying to better understand if I could simply deploy the code to the cRIO, have it launch an application on start up, and then work with it using a mouse \ keyboard \ monitor all directly connected to it versus needing a host computer to monitor the software execution.
I was originally thinking that the console port out would be able to provide a display, but the more I've read through the manual - that just seems to be an option to connect to a host PC so someone could make configuration changes there.
The host port also seems like it's just a way of adding peripheral USB devices like storage, a keyboard, etc.
Perhaps I'm misunderstanding something? I'm referencing this manual below:
https://www.apexwaves.com/pdf/manuals/cRIO-9056/cRIO-905x-User-Manual.pdf
Any help would be appreciated.
(2,641 Views)
Accepted by Evan_Mi
There is a feature known as the embedded UI, but unfortunately not supported on cRIO-905x.
Which NI Real-Time Targets Support Embedded UI?
While cRIO-905X models do have x64 chipsets, these specific models do not have integrated graphics so embedded UI is not an option on these targets.
https://tmesystems.net/
(2,626 Views)
Do the cRIO 9058 and 9055 use ARMv7 or X86_64?
(1,991 Views)
All cRIO-905x use Intel x64 chipset.
(1,982 Views)
@Zy Ong
Do you know if that requires U-boot or GRUB2 for Ni Linux RT Embedded Systems using LabView using the cRIO-905x's?
(1,973 Views)
NI Linux RT uses GRUB bootloader. Reference: NI Linux Real-Time Security User Guide
For more information about NI Linux RT, see
Under the Hood of NI Linux Real-Time
GitHub - ni/nilrt: Tools to build NI Linux RT distribution.
(1,968 Views)
Okay.  I am just verifying it is not U-Boot for ARMv7.   GRUB 2 has better options for Secure Boot.
Thank you! 🙂
(1,965 Views)
