cRIO 9066 maximum serial rate
Hello.
I would like to know the maximum baud rate for the serial port on CompactRIO 9066. I couldn't find it in the manual.
Kind regards,
Daniel
(4,735 Views)
How fast do you need it to go?  I see the console mode has a buad rate of 115200.  I have yet to run into an instrument that needs a faster rate than that.
(4,727 Views)
The baud rate I need is 921600, to troubleshoot communication with a wireless base station from Microstrain.
(4,713 Views)
Accepted by Daniel_Chile
The max baud rate from all the cRIO-906x devices is 230.4 kbps. CAR 554278 was filed to have that information included in all the specifications manuals, but in the meant time, the serial specifications will be equivalent to the cDAQ-9068's.
Camilo V.
(4,648 Views)
Ok, Camilo. Thanks for the information.
Daniel R.
(4,641 Views)
