cRIO 9068 + Scan Engine Support Error - Even though it is installed on cRIO, after deploying error says its missing
On the other hand, when I tried to deploy the modules the first time, a dialog box showed up saying some modules require the Scan Mode to be Active.  It also had a drop down box that allowed you to change to Active mode or stay in currrent mode.  The first time I chose to switch to Active mode, this time I stayed in current mode.  Does anyone know if selecting to change to Active mode in this case would cause problems with deploying modules?
Message 11 of 12
(3,219 Views)
Hi goveiaba,
I would recommend you create a new Post to address this that is a completely different issue. I can tell you that it is actually recommended have the Scan Mode in Configuration when working with EtherCAT:
AGJ
Message 12 of 12
(3,201 Views)
