cRIO 9082 - Cannot connect through NI MAX/LV
Hello all,
I'm currently writing my bachelor's thesis on dynamics and testing of vibrations.
As a part of the project I'm designing a experimental platform used to excite certain mechanical components.
As we need several sensors (PZT, accelerometers, DC motors etc.), we're using a cRIO 9082.
However, when i want to connect to the cRIO i cannot see it in NI MAX, i.e. i can't configure it. I can only see it in the NI Browser (see attached picture).
I'm connected directly to the cRIO through a crossover cable and the IPv4 is set to automatically assign the IP adress.
Any ideas of how i connect properly to the cRIO 9082.
I'm new to working with this kind of electronics, since i'm majoring in mechanical engineering - so please keep explanations as simple as possible 😉
If you need more details, please let me know.
Thanks in advance.
JZaulich.
(6,435 Views)
Hi JZaulich.
According to your screenshot from NI Network Browser, your cRIO has been assigned 169.254.173.43 as IP-adress. If your RIO is connected directly to your computer, and you haven't assigned a static IP, that IP is what we expect to get assigned. It is called a Link Local adress; that means, if the controller cannot initiate a DHCP connection, it will connect to the network with a link-local IP address.
Normally you should be able to see your device in MAX, but it can be that you have a firewall blocking, or something similiar. Try to do the following:
1) Right click on 'Remote Systems' and select 'Create New'
2) Choose 'Remote Device (not on the local subnet), and click 'Next'
3) In the IP-adress, type the IP-adress you see in the network browser.
Hopefully, this will add your cRIO system to MAX.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(6,406 Views)
Accepted by topic author JZaulich
Hey Alex,
Thank you very much for your reply.
I had to disable the Windows firewall as well as the AVG Firewall, which did the trick.
Apparently Windows doesn't allow this type of connection.
After disabling the firewall, i added the cRIO using the IP-adress and it seems to be working fine.
Thanks again.
Jakob Zaulich
(6,404 Views)
Hi Jakob.
Great. I'm glad that helped.
Now you can continue working on the fun stuff 🙂
Best Regards
Alex E. Munkhaus
System Engineer
(6,402 Views)
