waveform generation in real time
Currently, I am using a PXI with a FPGA module to do waveform form injection.  I would store all the samples of 1 cycle of the waveform in the block RAM and achieve/output them via the FPGA.  Can I do similar waveform injection with real time only?  What ware the limitation?  Thanks!
Kudos and Accepted as Solution are welcome!
(6,342 Views)
Hi jyang72211,
When you say waveform injection, do you mean you are writing data out on your R-series card i.e. an analog output task? What card and controller are you using?
Rahul B.
(6,300 Views)
Yes, writting data out on on R-series.  I am using a PXI-7833R at the moment.  The real time option is not available.  I am just wondering can I do that in real time.
(6,291 Views)
Hey jyang,
You can't generate a signal out of an R-series card without going through the FPGA because all of the I/O channels go through the FPGA. Along those lines, Scan Engine is not possible on an R-series card as is on a cRIO (though if you were trying to run Scan Engine on an R-series card, you would basically have a DAQ card).
Rahul B.
(6,268 Views)
I understandt hat for my device, I can only generate the waveform through the FPGA.  I am wondering can I use a real time device to do the same thing.
(6,255 Views)
Hi jyang72211,
I'm sorry if I misunderstood. Are you asking whether you can use a normal PXI Analog Output card to generate a waveform using your PXI RT controller? If so, that is possible; you would just program in LabVIEW and deploy to your RT target as normal.
Rahul B.
(6,247 Views)
What are the pros and cons in doing waveform injection in real time versus fpga?
(6,218 Views)
