cRIO-9082 DMA bandwidth between RT and FPGA
Good morning,
I would like to know DMA bandwidth of cRIO-9082 between FPGA and RT? How many MB/s? I can not find answer on NI web page.
I know that there are 3 DMA channels but how fast I could send data from FPGA to RT memory?
What is optimal size of element in DMA channel? U8, U16, U32 or U64?
Hardware: cRIO-9082 RT
Software: LabVIEW 2012, LabVIEW 2012 FPGA
Best regards
 Peter
 CLA
(7,151 Views)
Response from NI UK support:
FPGA and RT (RAM) are connected by PCI bus.
Theoretical maximum is 133.3 Mbits/sec.
Normal transfer bandwidth is between 90-100 Mbit/sec.
(7,128 Views)
Don't you mean 133 MB/sec or 1.06 Gbps as theoretical maximum of PCI?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,955 Views)
Accepted by JCC_(SK)
Response from NI UK support and correction by ThiCop:
Theoretical maximum is 133.3 MB/s.
Normal transfer bandwidth is between 90-100 MB/s.
(6,944 Views)
