cRIO filename restrictions/constraints
Looking for documention for cRIO-9074 that describes the restrictions/constraints for filenames.  Max length?  Forbidden characters?
(3,298 Views)
Hi Wayne,
I don't think there is specific documentation on these two items but the max length of the file path should be somewhere around 255 characters and as long a you stick with Letters, Numbers and underscores you shouldn't have a problem with forbidden characters.
<Brian A | Applications Engineering | National Instruments>
(3,283 Views)
"#" will give you problems.  I am not able to do anything with the file in cRIO.
Ian
(2,741 Views)
