error 537955 while using CompactRIO Waveform Library
Hi there ,
I have crio-9064 and analog input module 9222. I am using "Cont Acq.vi" ( with SAR FPGA vi ) example from CompactRIO Waveform Library to aquire and display data. I randomy get error 537955. I have attached a picture of the error. I am not sure why the error occcurs sometimes and other time the vi works fine. Could you please help.
I would approciate your help.
(3,456 Views)
Accepted by topic author brm11
Did you see this thread? They had the exact same error and there are some troubleshooting steps in there
http://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/170/page/3/thread-id/997179
(3,453 Views)
Thank you. I used the "Abort execution" button (it will cause the issue), if I use the Stop button on the VI interface, all is ok.
Thansk for your help
(3,393 Views)
