error 537955 while using CompactRIO Waveform Library
Hi there ,
I have crio-9064 and analog input module 9222. I am using "Cont Acq.vi" ( with SAR FPGA vi ) example from CompactRIO Waveform Library to aquire and display data. I randomy get error 537955. I have attached a picture of the error. I am not sure why the error occcurs sometimes and other time the vi works fine. Could you please help.
I would approciate your help.
(3,453 Views)
Accepted by brm11
Did you see this thread? They had the exact same error and there are some troubleshooting steps in there
http://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/170/page/3/thread-id/997179
(3,450 Views)
Thank you. I used the "Abort execution" button (it will cause the issue), if I use the Stop button on the VI interface, all is ok.
Thansk for your help
(3,390 Views)
